1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Breakpoint Table Error
Date: Mon, 21 Mar 2011 13:59:41 -0400
Learned Friends:
I am having trouble with the breakpoint table conversion in an analog input record.
The definitions of the offending records are attached below.
EPICS versions tried are 3.14.9 and 3.14.10.
"calib1" is  an ai record of type "Raw Soft Channel."
It should convert its raw value via the .LINR = typeKdegC breakpoint table.
Instead, VAL is equal to RVAL and STAT is "Soft."
"calib2" is a copy of "calib1" but uses .LINR = LINEAR.
It works fine.
Theyr'e both shown in this CSS screen shot:
https://www.msu.edu/~steine13/css_bpt.png
Any help or suggestions is greatly appreciated.
-Mathias
Mathias Steiner
Michigan State University
517-908-7423
# This provides the raw input value
record(ao, "mste:calinp")
  field(DESC, "input to calib1; bpt test")
  field(VAL, "5")
  field(PREC, "2")
record(ai, "mste:calib1")
  field(DESC, "testing breakpoint table")
  field(DTYP, "Raw Soft Channel")
  field(PREC, "2")
  field(INP, "mste:calinp CP NMS")
  field(LINR, "typeKdegC")
record(ai, "mste:calib2")
  field(DESC, "calibration test 2")
  field(PREC, "2")
  field(LINR, "LINEAR")
  field(ESLO, "10.0")
  field(EOFF, "100.0")
Re: Breakpoint Table Error Andrew Johnson
Prev: Re: error 'Library not loaded' for virtual linac Andrew Johnson
Next: Re: Breakpoint Table Error Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: some CAJ and JCA questions John Dobbins
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
