1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Breakpoint Table Error
To: [email protected]
Date: Mon, 21 Mar 2011 13:40:46 -0500
Hi Mathias,
On Monday 21 March 2011 12:59:41 Steiner, Mathias wrote:
> "calib1" is  an ai record of type "Raw Soft Channel."
> It should convert its raw value via the .LINR = typeKdegC breakpoint table.
> Instead, VAL is equal to RVAL and STAT is "Soft."
Did you include the bptTypeKdegC.dbd when you built your IOC's dbd file?
Those symptoms lead me to suspect that the breakpoint table data isn't
actually loaded at all — the standard table definitions are provided with Base
and their names are listed in the menuConvert.dbd file, but you have to
explicitly include the relevant .dbd file when building an IOC that uses it.
That might not be documented anywhere though (sorry!).
HTH,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
RE: Breakpoint Table Error Steiner, Mathias
Prev: Breakpoint Table Error Steiner, Mathias
Next: RE: Breakpoint Table Error Steiner, Mathias
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
