1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: waveform transformation
To: EPICS tech-talk <[email protected]>
Date: Mon, 21 Mar 2011 16:42:00 -0700
Hello,
I have a waveform.
I would like to apply a linear transformation to that waveform.
The simplest case would be
* calibration of ADC raw values to voltages
* transformation from voltage to engineering units
Is there a simple way to do this?
Ultimately I would like to use a subArray....
So far the only way I have found to do the above is to this is by transforming the waveform in the C code.
Is it possible to do the same in the IOC database?
Emmanuel
Re: waveform transformation Tim Mooney
Prev: RE: epicsqt first try Andrew Rhyder
Next: non-normalized X WaveF / Y WaveF display emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Breakpoint Table Error Steiner, Mathias
Next: Re: waveform transformation Tim Mooney
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
