1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: non-normalized X WaveF / Y WaveF display
To: EPICS tech-talk <[email protected]>
Date: Mon, 21 Mar 2011 16:58:55 -0700
Hello,
I am using medm.
I have a network anylizer that scans/samples frequency ranges.
I would like to represent the results in X/Y format using medm.
Y: sample value
X: frequency
200 samples
I assume I have to generate the X waveform = # samples on frequency range.
But can medm autoscale on the horizontal axis since range and # of samples can be changed at every scan by operator?
(I believe so, but ...)
I would like to have a 'cursor' that moves on the waveform.
Has anyone tries this in medm?
How did you do this?
(A possible solution could be to use the sample number i and extract the (X[i],Y[i]),
 2 subarrays of 1 elements...)
Is this asking for too much from medm ? ;-)
Can edm or other epics gui do this?
Emmanuel
Re: non-normalized X WaveF / Y WaveF display Eric Norum
Prev: waveform transformation emmanuel_mayssat
Next: epicsqt emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: waveform transformation Tim Mooney
Next: Re: non-normalized X WaveF / Y WaveF display Eric Norum
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
