1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: a puzzle about using stream device driver
To: <[email protected]>, "tech-talk" <[email protected]>
Date: Mon, 20 Jun 2011 11:21:20 -0400
A simple way to get different scan rates based on a binary status.  I
haven't checked that this example works, but I think it gives the basic
idea.
Record(bi, "$(P)moving") {
Record(fanout, "$(P)slow") {
  Field(SDIS, "$(P)moving")
  Field(DISV, "1")
  Field(SCAN, "1 second")
  Field(FLNK, "$(P):opticalscale")
Record(fanout, "$(P)fast") {
  Field(DISV, "0")
  Field(SCAN, ".1 second")
Record(ai, "$(P):opticalscale") {
Behavior of SDIS and DISV is described here:
http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-14_dbCommon
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Silver
> Sent: Monday, June 20, 2011 10:42 AM
> To: tech-talk
> Subject: a puzzle about using stream device driver
> hi,
> I am using stream device driver to communicate a galil motion control
> which model is dmc21x3. To  get the value of optical scale, I use a ai
> record like this:
> record(ai,"$(PREFIX):opticalscale")
>         field (DESC, "opticalscale position")
>         field (DTYP, "stream")
>         field (INP, "@dmc2143.proto ai_opticalscale motor")
>         field (SCAN, ".5 second")
> In that, I use the period scan. It works fine.
> But in most of time, the value doesn't change. That means the IOC has
> to communicate with device periodly. As the value only changes during
> the motor moving,  may I use I/O Intr mode?
> I checked the online document of stream device, seems the I/O Intr
mode
> is not suitable for this case. Is there any good ways to avoid
checking
> the devcie periodly?
> Thanks a lot for your help.
> Best regards
> Geyang  2011-06-20
Re: a puzzle about using stream device driver Dirk Zimoch
a puzzle about using stream device driver Silver
Prev: RE: radiation damage to electronics inside accelerator tunnel? austen.rose
Next: EPICS_DEPRECATED and gcc-2.96 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: a puzzle about using stream device driver Mark Rivers
Next: Re: a puzzle about using stream device driver Dirk Zimoch
