1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer news: latest snapshot
To: "Pelaia II, Tom" <[email protected]>
Date: Mon, 27 Jun 2011 12:44:31 -0500
On 6/27/11 12:34 PM, J. Lewis Muir wrote:
> On 6/27/11 12:15 PM, Pelaia II, Tom wrote:
>> If you really want the EPICS_HOST_ARCH to report "64" just
>> enable the 64 bit kernel (as I have). It is easy if your
>> hardware supports it.
> Hi, Tom.
> I don't know what you mean by this.  I set the EPICS_HOST_ARCH
> environment variable by hand.  What kernel I'm running has
> nothing to do with what value EPICS_HOST_ARCH contains since I
> set it myself.  And of course the Mac OS X kernel knows nothing
> about the EPICS_HOST_ARCH environment variable.  Plus, the only
> supported EPICS Darwin architectures which EPICS_HOST_ARCH could
> be set to that I know of are darwin-ppc, darwin-ppcx86, and
> darwin-x86, none of which contain "64".  What am I missing?
Hi, Tom.
Maybe you're using the startup/EpicsHostArch script from EPICS
Base to set EPICS_HOST_ARCH?  I just tried that from EPICS Base
3.14.12.1 and it printed "darwin-x86_64" and exited with a 0
exit status.
$ ./startup/EpicsHostArch
darwin-x86_64
Andrew, I don't think that's correct.  My CPU is 64-bit.  I
think the script should probably print "darwin-x86" or
"darwin-ppcx86".  Or maybe the script should support printing
what ARCH_CLASS should be set to as well?
The perl version (i.e. startup/EpicsHostArch.pl) prints
"unsupported" without a newline and exits with a 0 exit status.
Lewis
Re: Sequencer news: latest snapshot Andrew Johnson
Re: Sequencer news: latest snapshot Pelaia II, Tom
Sequencer news: latest snapshot Benjamin Franksen
Re: Sequencer news: latest snapshot Benjamin Franksen
Re: Sequencer news: latest snapshot J. Lewis Muir
Prev: Re: Sequencer news: latest snapshot J. Lewis Muir
Next: Re: Sequencer news: latest snapshot Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
