1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime
To: <[email protected]>
Date: Mon, 4 Jul 2011 08:48:00 +0000
When I was using the ip330 in Continuous mode I found it necessary to set the gain a couple of times in my startup file in order to get it to run:
record(longout,"BL18I-EA-IONC-01:IGain")
        field(PINI,"YES")
        field(VAL,"0")
        field(DTYP,"asynInt32")
        field(OUT,"@asyn(ip330b 0)GAIN")
And in the startup file:
dbpf ("BL18I-EA-IONC-01:IGain","1")
dbpf ("BL18I-EA-IONC-01:IGain","0")
Note sure if this is relevant to you but it may be worth trying when you switch back to continuous mode.
Pete Leicester
Diamond Light Source
From: [email protected] [mailto:[email protected]] On Behalf Of Jay Steele
Sent: 29 June 2011 19:20
To: [email protected]
Subject: problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime
Hi EPICS folks,
     I’m seeing a problem with the EPICS module for the VME ADC board IP330, software version 2-6. I’m trying to switch between Burst Continuous and Burst Single modes for step scanning and hardware-synchronized fly scanning, respectively, at run time. When I process the provided ScanMode record, the board gets stuck in Burst Single mode no matter if I’m setting the Burst Continuous mode (value 3) or Burst Single mode (value 4).
    Has anybody else been successful at switching modes at run time for the IP330 board using this software?
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
RE: problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime Jay Steele
Prev: RE: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Utzel Nadine
Next: CAJ maintainer, anyone? Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime Jay Steele
Next: RE: problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime Jay Steele
