1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: streamdevice + asyn stuck
To: "Zhang, Dehong" <[email protected]>, "Eric Norum" <[email protected]>, <[email protected]>
Date: Thu, 14 Jul 2011 21:29:37 -0500
Hi Dehong,
> I try very hard not to set the records do "SCAN ** second", but let them listen
> to certain events and process at different phases, so that I can be sure they
> don't ever scan at the same moment.
That should not be a problem at all.  Your devices are all talking to an underlying asyn port driver.  You said you are using a Digi, so I assume you are using the drvAsynIPPort driver?  If so, it takes care of serialization so that it is fine for multiple records to be talking to the IP port "at the same moment".  The only thing you need to worry about is that you use device support that guarantees that write/reads are atomic.  The standard asyn device support does this, and I am sure that streamDevice does as well.
streamDevice with asyn has been used pretty extensively for systems like yours, without such problems.  If the network or Digi is sometimes messing up then you should just get an asyn timeout.
I am beginning to suspect what Eric Norum suggested, i.e. that some other component in the system is perhaps running amok and causing this problem as a side-effect.
Here is a suggestion:  make a bare-bones IOC which only runs this device.  Then you can rule out other software as causing the problem.
I have looked through your messages and I don't see mention of what OS you are using?  Linux, RTEMS, etc?
Also you are running asyn R4-10 which is 3 years old, and base 3.14.9 which is 4.5 years old.  You could try base 3.14.12.1 and asyn 4-16 to see if the problem persists.
Sent: Thu 7/14/2011 8:11 PM
To: Eric Norum; [email protected]; Mark Rivers
Cc: EPICS Tech Talk
Hi Dirk, Eric and Mark,
The effect of my hack is unknown -- the problem is still happening.
Here is what I did (my system does not use any wait command):
bool StreamCore::
startProtocol(StartMode startMode)
added:
    // start a global timeout watch-dog
    flags |= WaitPending;
    startTimer(10000);
right before:
    return evalCommand();
void StreamCore::
finishProtocol(ProtocolResult status)
added:
    flags &= ~WaitPending;
in the very beginning, before:
    if (flags & BusPending)
bool StreamCore::
evalCommand()
changed the first line to:
    if ((flags & ~WaitPending) & BusPending)
void StreamCore::
timerCallback()
commented out:
//      error("StreamCore::timerCallback(%s) called unexpectedly\n",
//          name());
changed the last line:
//  evalCommand();
    // it has been too long, abort the protocol
    finishProtocol(Fault);
Please check this.  If my implementation is correct, then there is only one suspect
left: the callbackRequest in
void Stream::
protocolFinishHook(ProtocolResult result)
Is this handled by Epics base?  The parameter callbackQueueSize is rather large,
at 2000.  Should I try to increase it?  Guess I need to do it before iocInit.
Another thing, the callback priority seems to be set to low.  Should I raise it?
don't ever scan at the same moment.  After all this, there should not be much
chances for resource contention.  I feel that the problem is happening less
often, but still there.
Any ideas?
Thanks much for helping!  Best regards,
Dehong
Sent: Wednesday, July 13, 2011 6:46 PM
To: Zhang, Dehong
Cc: EPICS Tech Talk
Subject: Re: streamdevice + asyn stuck
Intermittent strange behaviour sometimes results from a runaway pointer elsewhere in the program, stack overflow, accessing malloc'd memory beyond its range or after it's been freed.   All of which can be tricky to track down.............
On Jul 13, 2011, at 6:26 PM, Zhang, Dehong wrote:
> Hi Dirk and Mark,
> The problem is not the mutex.  I followed Mark's suggestion and did not see
> any mutex stuck -- very often got an empty list.
> The problem does not happen very often.  It seems the (random) frequence
> depends on the time/environment?  I am having a hard time to catch a case
> before the log file reaches the 2 GB limit.
> Honestly, I really admire Dirk's effort to put together such a big piece of work!
> It is so useful!  And so flexible of cource!  I did not know anything about it,
> can only be amazed the more I read the documents and code.  I don't think
> there is anything wrong.  It is only the situation we are dealing with: the
> computer, the network, digi, then all kinds of hardware with different quality.
> I strongly believe the problem is caused by losing communication, due to
> network glitches, or digi dropping messages (I have a definitive prove of this),
> or the firmware of the actual hardware.
> Since the package already has a timer, and one of my systems is not using
> (yet) the wait command, I hacked the code slightly, to implement a global
> timeout -- if the protocol does not finish within like 10 seconds, the timer will
> abort the protocol.  This should "catch-all".  Let's watch it for a few days!
> Any new ideas?
> Best regards,
> Dehong
> From: Dirk Zimoch [[email protected]]
> Sent: Wednesday, July 13, 2011 12:47 AM
> To: Zhang, Dehong
> Cc: [email protected]; [email protected]
> Hello Dehong,
>> Hi Dirk and Mark,
>> Thank you very much for helping!
>> I tried to change the SCAN to "10 second", it did not help.  I also tried the
>> epicsThreadShowAll command as Dirk suggested, it shows a few timerQueue
>> threads, all "OK"
> Some time ago I had the problem that I crashed the timerQueue thread in
> a timeout callback and thus never completed record processing. However,
> this seems to be a different issue because you don't see crashed threads.
>>> From what I can see from the source code, I believe that we somehow
>> lose callbacks from asyn, that breaks the evalcommand() chain and we
>> never get to finishProtocol().
> Yes. That seems to be the case. At several places, StreamDevice gives
> control to asyn or to EPICS base and relies on callbacks. If the
> callbacks don't come, StreamDevice is lost.
> I have to check if I did anything wrong there. Basically I give control
>  to asynDriver using queueRequest() and expect a callback either to
> handleRequest() or handleTimeout(). From there I call the individual
> event handlers. So maybe either my queueRequest() setup is wrong or my
> handlers are buggy or asynDriver never calls back. (all code in
> AsynDriverInterface.cc)
> Later I give control to EPICS base via callbackRequest() to finish
> processing the record. But I don't think that there is something wrong.
> (code in StreamEpics.cc)
> I will try to add some diagnostics to see what a record is currently
> waiting for. But that may take a while.
>> Another possibility is the mutex.  If it is not released properly, the
>> Stream::process() method will be stuck waiting.
> The mutex is automatically released (via destructor) when the function
> that contains the lock returns. Thus the only way to keep the lock is to
> get stuck in a function while holding the lock. But because I don't
> think I have unbounded loops in any function, that can only happen when
> a thread crashes or a function I call does not return. I don't think
> that happens.
> Please switch on debugging (var streamDebug,1). Better remove or disable
> all other StreamDevice records or the output will be overwhelming. What
> are the last messages you get from a record before is gets stuck?
> Dirk
>> Sent: Tuesday, July 12, 2011 12:21 AM
>> To: Zhang, Dehong
>> Hello Dehong,
>> Do you have a hung up timerQueue thread? Try epicsThreadShowAll.
>> Dirk
>>> Hi Dirk, Mark and fellow EPICSers,
>>> Sorry to bother you with this.  I tried to chase the source code and search the tech-talk,
>>> but could not find much hints.
>>> We use base 3.14.9, streamdevice 2.4 and asyn 4.10, have been experiencing this stuck
>>> problem for some time.  The symptom is that randomly, a mbbi/ai/bi... (input) record would
>>> stop updating and no longer does FLNK, with no error/warning messages printed in the log
>>> file.  And dbpr *** 3 would show that:
>>> LCNT=11
>>> SEVR=INVALID
>>> STAT=SCAN
>>> And manually writing to the PROC field also does nothing.
>>> It seems like the record is stuck waiting for a callback from streamdevice (and asyn), and
>>> the EPICS framework just ignores any "PROC" requests.
>>> In the protocol file we do have the timeouts etc:
>>> locktimeout  = 5000;
>>> terminator   = CR;
>>> replytimeout = 1000;
>>> readtimeout  = 1000;
>>> extrainput   = Ignore;
>>> While chasing the problem, I noticed that "asynReport 10 ***" would show:
>>> multiDevice:No canBlock:Yes autoConnect:Yes
>>>    enabled:Yes connected:Yes numberConnects 1
>>> For some the numberConnects can be 2.
>>> Is this "canBlock:Yes" related to my problem?  Should the numberConnects be <=1?
>>> We use one port to talk to one device.
>>> Rebooting the IOC does fix the problems, but then they would come back, randomly.
>>> Please advise.  Thank you very much.
>>> Best regards,
>>> Dehong
Eric Norum
[email protected]
Re: streamdevice + asyn stuck Dirk Zimoch
RE: streamdevice + asyn stuck Zhang, Dehong
Re: streamdevice + asyn stuck Eric Norum
Prev: RE: streamdevice + asyn stuck Zhang, Dehong
Next: Re: streamdevice + asyn stuck Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
