1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 'open' epics backup?
To: "<[email protected]>" <[email protected]>
Date: Thu, 25 Aug 2011 16:10:11 -0400
At SNS we use the SCORE application which is part of XAL to save and restore PV values. Users can save and restore snapshots (stored in a database) and compare them with the live values. Saving and Restoring is currently on demand.
- Tom
On Aug 25, 2011, at 1:25 PM, <[email protected]> wrote:
> On 12:41 Wed 24 Aug     , Pete Jemian wrote:
>> Not sure what type of backup you are considering.
>> Here's a couple tools or methods:
>> * persistence of PVs across IOC reboots: autosave, from synApps
>> * snapshots of a set of PVs at regular times: SDDS files
>> * time-series display of PVs: various including SDDS or rrdtool
> I am currently using SDDS and moving away from it.
> (no python support, no used outside of epics community)
> I looked at RRDtool.
> Although that is not a backup utility, that's definitly something I want to use to move away from
> timeseries using SDDS. (which I also use)
> Just a question: how do you take a time serie of thousands of PV with rrdtool at one time T?
> I assume you had to develop a ca plugin/utility, didn't you?
> When I talked about backup, I am refering to snapshot, which can be restored.
> sddscasr can do that. Anything else?
> As far as IRMIS is concerned, well although I don't know much about it, just hearing IRMIS sounds
> complicated. Reading the IRMIS primer is confusing. I just want to take a snapshot and IRMIS, it seems
> to me, can do everything ;-)
> Emmanuel
Re: 'open' epics backup? emmanuel_mayssat
RE: 'open' epics backup? Chu, Paul
Re: 'open' epics backup? Pete Jemian
Prev: Re: 'open' epics backup? Tim Mooney
Next: Re: 'open' epics backup? Peter Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 'open' epics backup? Pete Jemian
Next: Re: 'open' epics backup? emmanuel_mayssat
