1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 'open' epics backup?
To: "Pelaia II, Tom" <[email protected]>, "<[email protected]>" <[email protected]>
Date: Thu, 25 Aug 2011 19:15:25 -0700
At LCLS, XAL SCORE has been extended for the following features:
1. PVs in SCORE lists are checked against IRMIS signal table nightly.
2. Magnet field settings can be restored according to energy scaling, i.e. even machine was running at a different energy than the snapshot taken, the same physics lattice can be restored.
3. The GUI was slightly modified to better suit SLAC operation needs.
Paul
From: [email protected] [[email protected]] On Behalf Of Pelaia II, Tom [[email protected]]
Sent: Thursday, August 25, 2011 1:10 PM
To: <[email protected]>
Cc: [email protected]
Subject: Re: 'open' epics backup?
At SNS we use the SCORE application which is part of XAL to save and restore PV values. Users can save and restore snapshots (stored in a database) and compare them with the live values. Saving and Restoring is currently on demand.
- Tom
On Aug 25, 2011, at 1:25 PM, <[email protected]> wrote:
> On 12:41 Wed 24 Aug     , Pete Jemian wrote:
>> Not sure what type of backup you are considering.
>> Here's a couple tools or methods:
>> * persistence of PVs across IOC reboots: autosave, from synApps
>> * snapshots of a set of PVs at regular times: SDDS files
>> * time-series display of PVs: various including SDDS or rrdtool
> I am currently using SDDS and moving away from it.
> (no python support, no used outside of epics community)
> I looked at RRDtool.
> Although that is not a backup utility, that's definitly something I want to use to move away from
> timeseries using SDDS. (which I also use)
> Just a question: how do you take a time serie of thousands of PV with rrdtool at one time T?
> I assume you had to develop a ca plugin/utility, didn't you?
> When I talked about backup, I am refering to snapshot, which can be restored.
> sddscasr can do that. Anything else?
> As far as IRMIS is concerned, well although I don't know much about it, just hearing IRMIS sounds
> complicated. Reading the IRMIS primer is confusing. I just want to take a snapshot and IRMIS, it seems
> to me, can do everything ;-)
> Emmanuel
'open' epics backup? emmanuel_mayssat
Re: 'open' epics backup? Pete Jemian
Re: 'open' epics backup? emmanuel_mayssat
Re: 'open' epics backup? Pelaia II, Tom
Prev: Re: 'open' epics backup? emmanuel_mayssat
Next: Re: RDD of epics pv Pete R. Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: 'open' epics backup? Peter Jemian
