1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RDD of epics pv
To: Peter Jemian <[email protected]>
Cc: [email protected]
Date: Thu, 25 Aug 2011 16:24:21 -0700
I am  familiar with the excellent pyepics, but not yet with RDDtools.
Could you please send me a copy of your python and RDD scriptS so I better understand?
Also, I assume you can plot different process variables (from
different RDD db) on the same graph with your framework. Is this
correct?
E
On 16:20 Thu 25 Aug     , Peter Jemian wrote:
> > I looked at RRDtool.
> > Although that is not a backup utility, that's definitly something I
> > want to use to move away from
> > timeseries using SDDS. (which I also use)
> > Just a question: how do you take a time serie of thousands of PV with
> > rrdtool at one time T?
> > I assume you had to develop a ca plugin/utility, didn't you?
> Built support for a specific beam line in Python using PyEpics.
> Set CA monitor on each PV.  Python job runs in the background.
> Cron job checks periodically to make sure python job restarts
> if python job has excepted out.
> The supported beam line has ca. 10^2 PVs which is not the same load as your O(10^3) PVs.  Interesting to try.  In my scheme, each PV gets its own RRD database.  Easier to add new PVs without perturbing the existing ones.
> Pete
Emmanuel
Re: RDD of epics pv Pete R. Jemian
Prev: Re: 'open' epics backup? Peter Jemian
Next: Re: 'open' epics backup? emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing virtual linac. Permission denied (noob question) J. Lewis Muir
Next: Re: RDD of epics pv Pete R. Jemian
