1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: 'open' epics backup?
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Thu, 25 Aug 2011 16:41:09 -0700
> I use BURT for this.
> http://www.aps.anl.gov/epics/extensions/burt/index.php
Ok, for BURT without sdds.
Just out of curiosity,
1/ can you restore a subset of your PVs instead of a complete restore?
2/ is there a utility to compare BURT snapshot?
3/ How do you generate a req file? dbl + manual edit ?
4/ what does the Notify means in the Read Only Notify (RON), a popup
in the GUI? In which case would that be used?
5/ How does BURT compares to CASR in your opinion?
Emmanuel
Re: 'open' epics backup? Tim Mooney
Re: 'open' epics backup? emmanuel_mayssat
Prev: RDD of epics pv emmanuel_mayssat
Next: Re: 'open' epics backup? emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: 'open' epics backup? Tim Mooney
Next: Re: 'open' epics backup? Tim Mooney
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
