1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aSub and zero length arrays
Cc: [email protected]
Date: Tue, 18 Oct 2011 11:55:59 -0400
On 10/18/2011 11:30 AM, Andrew Johnson wrote:
Hi Michael,
On 2011-10-18 Michael Davidsaver wrote:
I've stumbled onto an interesting behavior of aSub.  I want to write a
function which takes a CHAR array as input (a long string).  Sometimes
the string can legitimately be empty (length 0).  What I find is that
when the the input should go from non-empty to empty it does not, and
instead keeps the previous value.
The number of elements of a long string (char array) must always include the
terminating nil character, thus an empty string must have an element count of
one, not zero.  If you don't include the terminator in your element count your
string might get old garbage appended to it.
Ok, so this covers the case of long strings. What about other types (eg. DOUBLE)? Isn't this an issue of general correctness/proper error reporting?
Michael
Re: aSub and zero length arrays Andrew Johnson
aSub and zero length arrays Michael Davidsaver
Prev: long strings Michael Davidsaver
Next: Re: How the EPICS IOC determines the link type {CA_LINK/DB_LINK/CONSTANT} Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: aSub and zero length arrays Andrew Johnson
