Juan,
The only widgets that deal directly with waveform of chars as a long
string are the text entry/update. The reason that your code is not
working is that setValue checks type and the type created by
createIntArray (int[]) is not one of the recognized types. Integer []
is supported so if you can create this ( I'm just not that fluent in
Javascript ) then I think that you can do what you want.
I have done a test edit of the code and have come up with the following
patch that will allow passing int[] to the setValue so that your
original script should work, although I had trouble since you created an
array of 10 elements but had a longer string. This section of code is
not mine so I am going to pass this off to others in the group to accept
& commit. This will not fix your immediate issue but should make it
possible to do this in the future.
John Hammonds
diff -r a6e2537a9c5c
core/plugins/org.csstudio.utility.pv.epics/src/org/csstudio/utility/pv/epics/EPICS_V3_PV.java
a/core/plugins/org.csstudio.utility.pv.epics/src/org/csstudio/utility/pv/epics/EPICS_V3_PV.java
Thu Oct 27 13:54:01 2011 -0500
b/core/plugins/org.csstudio.utility.pv.epics/src/org/csstudio/utility/pv/epics/EPICS_V3_PV.java
Wed Nov 23 10:58:49 2011 -0600
@@ -495,7 +495,7 @@
final int val = ((Integer)new_value).intValue();
channel_ref.getChannel().put(val);
- else if (new_value instanceof Integer [])
+ else if (new_value instanceof Integer [] )
final Integer ival[] = (Integer [])new_value;
final int val[] = new int[ival.length];
@@ -503,8 +503,12 @@
val[i] = ival[i].intValue();
+ else if (new_value instanceof int[])
+ channel_ref.getChannel().put((int[])new_value);
} else {
- throw new Exception("Cannot handle type "
+ throw new Exception("Cannot handle data type "
+ new_value.getClass().getName());
On 11/23/2011 7:27 AM, [email protected] wrote:
I have a waveform record setup as array of char (to support long string) and I'm trying to write a string to it via BOY Action button. I setup a "Write PV" action in the widget but the string does not get written, so perhaps long strings are not supported in BOY actions (it works for Text Inputs).
I tried a Javascript code to convert the string to an array of char via the following code:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
var strArray = DataUtil.createIntArray(10);
var pv = widget.getPV();
var strText = "this is a test";
for(var i=0; i<strText.length; i++) {
strArray[i] = strText.charCodeAt(i);
pv.setValue(strArray);
but the script throws an exception in BOY's console "Wrapped java.lang.Exception: Cannot handle type [I".
Is there any way in BOY to write a string to a waveform record as an array of char (support long strings)? I'm using SNS CSS 3.0.2 (Basic) for MacOSX.
Thanks in advance,
Juan.
Juan Carlos Guzman
Software Engineer
Australia Telescope National Facility
CSIRO Astronomy and Space Science
P.O.Box 76, Epping NSW 1710, Australia
Phone: +61 2 9372 4457
Fax: +61 2 9372 4310
Email: [email protected]<mailto:[email protected]>
John Hammonds
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
(630)252-5317
- RE: Writing long strings PV in BOY Chen, Xihui
- Writing long strings PV in BOY Juan.Guzman
Re: Gateway binary distribution available for RedHat 5.5 Martin Konrad
<2011>
2025
<2011>
2025
