Subject: Re: autosave application loading error
From: "Williams Jr., Ernest L." <[email protected]>
To: Zhang Yuliang <[email protected]>
Date: Tue, 3 Jan 2012 19:51:01 -0800
Please add nfs support to your vxWorks kernel image
That should resolve your problem
Cheers
Ernest
Sent from my iPhone
On Jan 3, 2012, at 18:23, "Zhang Yuliang" <[email protected]<mailto:[email protected]>> wrote:
Hi All,
Recently I tried to use autosave Module and I downloaded autosave_R4-4.  I created a new EPICS application named asApp, and successfully built the application following the build step in the documention mentioned in "autoSaveRestore.html" . When I load the EPICS application to target VEM5100, the error occured:
ld < asApp.munch
Undefined symbol: nfsMount (binding 1 type 0)
Undefined symbol: nfsUnmount (binding 1 type 0)
ld error: Module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
The related software I am using is: EPICS Base-3.14.8.2, vxWorks5.5.1(Tornado 2.2.1).
Thank you !
Zhang Yuliang
Re: Re: autosave application loading error Zhang Yuliang
Prev: Re: RTEMS-MVME2300 Michael Davidsaver
Next: Re: RTEMS-MVME2300 Eric Norum
Prev: autosave application loading error Zhang Yuliang
Next: Re: Re: autosave application loading error Zhang Yuliang
