Subject: |
Re: assert(!epicsThreadPrivateGet(caClientContextId)) failed when loading mrfioc2 |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 4 Jan 2012 17:05:17 -0600 |
Hi 王林,
On 2012-01-04 王林 wrote:
> -> </home/wanglin/mrfioc2-2.0.0/iocBoot/iocevrmrm/st.cmd
> ## mrfioc2 vxWorks startup file
> cd "/home/wanglin/mrfioc2-2.0.0"
> value = 0 = 0x0
> ld < bin/vxWorks-ppc604_long/evgMrm.munch
> value = 52510128 = 0x3213db0
> ld < bin/vxWorks-ppc604_long/evrtest.munch
> value = 41164064 = 0x2741d20 = ' '
> ld < bin/vxWorks-ppc604_long/mrf.munch
> value = 41141760 = 0x273c600
You are loading 3 separate .munch files there, and I suspect you're actually
loading 3 separate copies of libCom and hence of the epicsThreadPrivate
routines, thus causing the assertion you reported. Please try modifying your
build so that you link all your code into a single file and try loading that
instead — in EPICS 3.13 we supported loading things separately, but in 3.14
that is actually quite hard to do correctly, so we discourage doing it.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Re: assert(!epicsThreadPrivateGet(caClientContextId)) failed when loading mrfioc2 王林
- assert(!epicsThreadPrivateGet(caClientContextId)) failed when loading mrfioc2 王林
RE: assert(!epicsThreadPrivateGet(caClientContextId)) failed when loading mrfioc2 Jeff Hill
<2012>
<2012>
