1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Motor module "unknown bit order" compiler error with vxWorks-mpc8548
Date: Wed, 4 Jan 2012 17:15:05 -0800
When I try compiling the motor module for vxWorks-mpc8548 I get an "unknown bit order" error (see below).
It looks like the CPU type for vxWorks-mpc8548 is PPC32 because if I add PPC32 to the motor.h file, it compiles ok.
I set the bit fields to be packed MSB first.  Is this correct?
/* Define, from top to bottom, how bit fields are packed. */
/* This works for gnu, SunPro, MS Visual C. */
#if defined(_WIN32) || defined(_M_IX86) || defined(_X86_)
    #define LSB_First (TRUE)  /* LSB is packed first. */
#elif defined(__i386__) || defined(_armv4l_) || defined(_X86_64_) || defined(__APPLE__)
#elif defined(i386)
#elif defined(sparc) || defined(m68k) || defined(powerpc)
    #define MSB_First (TRUE)  /* MSB is packed first. */
#elif (CPU == PPC604) || (CPU == PPC603) || (CPU==PPC85XX) || (CPU == MC68040) || (CPU == PPC32)   /***** I added PPC32 CPU type here *****/
#else
    #error: unknown bit order!
#endif
Compile Error :
make -C O.vxWorks-mpc8548 -f ../Makefile TOP=../../.. T_A=vxWorks-mpc8548 install
make[3]: Entering directory `/afs/slac.stanford.edu/g/acctest/vol1/epics/modules/R3-14-12/motor/MAIN_TRUNK/motorApp/MotorSrc/O.vxWorks-mpc8548'
/afs/slac/package/vxworks/devel/6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -c            -DCPU=PPC32  -DvxWorks -DvxWorks -DBSD=44 -include /afs/slac/package/vxworks/devel/6.8/vxworks-6.8/target/h/vxWorks.h    -g   -Wall     -DCPU_VARIANT=_ppc85XX_e500v2 -te500v2 -mlongcall    -fno-builtin -fno-builtin -DBSD=44  -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/vxWorks -I../../../include                      -I/afs/slac/g/acctest/epics/modules/R3-14-12/ipac/ipac-R2-11-lcls1/include  -I/afs/slac/g/acctest/epics/modules/R3-14-12/asyn/asyn-R4-18-lcls1/include  -I/afs/slac/g/acctest/epics/modules/R3-14-12/seq/seq-R2-1-3-lcls1/include -I/afs/slac/g/acctest/epics/base/base-R3-14-12/include/os/vxWorks -I/afs/slac/g/acctest/epics/base/base-R3-14-12/include      -I/afs/slac/package/vxworks/devel/6.8/vxworks-6.8/target/h -I/afs/slac/package/vxworks/devel/6.8/vxworks-6.8/target/h/wrn/coreip ../motorRecord.cc
In file included from ../motorRecord.cc:177:
../motor.h:143:6: error: #error : unknown bit order!
make[3]: *** [motorRecord.o] Error 1
make[3]: Leaving directory `/afs/slac.stanford.edu/g/acctest/vol1/epics/modules/R3-14-12/motor/MAIN_TRUNK/motorApp/MotorSrc/O.vxWorks-mpc8548'
make[2]: *** [install.vxWorks-mpc8548] Error 2
make[2]: Leaving directory `/afs/slac.stanford.edu/g/acctest/vol1/epics/modules/R3-14-12/motor/MAIN_TRUNK/motorApp/MotorSrc'
make[1]: *** [MotorSrc.install] Error 2
make[1]: Leaving directory `/afs/slac.stanford.edu/g/acctest/vol1/epics/modules/R3-14-12/motor/MAIN_TRUNK/motorApp'
make: *** [motorApp.install] Error 2
Nia Fong
ICD Software
650-926-6215
[email protected]
Prev: Re: assert(!epicsThreadPrivateGet(caClientContextId)) failed when loading mrfioc2 王林
Next: [CA] how to properly set up CAS and clients Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Building base-3.14.12.2 on windows-x64 Mark Rivers
