Subject: Re: linux-gpib with asyn
To: [email protected]
Date: Wed, 11 Jan 2012 16:40:39 +0100
Hi Stuart,
we have recently set up a small linux box with ines_pci_gp5130 board.
See the small snipped from st.cmd how we call GpibBoardDriverConfig
#  GpibBoardDriverConfig(portName,autoConnect,BoardIndex,timeout,priority)
GpibBoardDriverConfig("L1",1, 0, 3.0, 0)
and content of file gpib.conf of that box:
more /etc/gpib.conf
                 GPIB.CONF IEEE488 library config file
   copyright            : (C) 2002 by Frank Mori Hess
                          (C) 1994 by C.Schroeter
   email                : [email protected]
 *   Syntax:
 *         interface { ... } starts new interface board section
 *         device {...} device configuration
interface {
        minor = 0
        board_type = "ines_pci_gp5130"
        name = "L1"
        pad = 0
        sad = 0
        eos = 0x0a      /* EOS Byte, 0xa is newline and 0xd is carriage
return */
        set-reos = yes  /* Terminate read if EOS */
        set-bin = no    /* Compare EOS 8-bit */
        set-xeos = no   /* Assert EOI whenever EOS byte is sent */
        set-eot = yes   /* Assert EOI with last byte on writes */
        master = yes
We have connected instruments of different vendors to the bus: Keithley,
HP, Datron and we also get replies where the first character is NULL. We
never saw this on an E5810 LAN-GPIB gateway, thus it must be due to the
board or linux-gpib driver.
Currently we are using epics 3.14.12.1 and asyn 4-16
What sw releases and kind of board are you using?
Regards
Peter
Am 09.01.2012 14:28, schrieb Wilkins, Stuart:
> Hi!
> I have been using linux-gpib and asyn (and StreamDevice) for
> communication with Keithley Electrometers. I have one comment on the
> documentation and one bug which I would like to see if anyone else has seen.
> Firstly, according to the asyn documentation the following command at
> the iocsh sets up the board.
>  From this documentation, it looks like you assign the GPIB board with
> the integer "board index", however after about 2 hrs of trying to get
> this working, I delved into the souce code for this driver. In fact,
> this is not the behavior in the code, the port driver tries to open the
> gpib card with the same name as the portName as defined in
> /etc/gpib.conf. I think (although in places the code is fairly cryptic)
> it is only if you open a certain gpib address that it uses board index,
> but I cannot find the config to give the primary and secondary address
> at the iocsh. It might be a good idea to update this in the asyn
> documentation (or at least clarify it!)
> Having got past this stage, I noticed that some of my communications are
> being garbled, with replies returning where the first character is NULL
> [chr$(0)] instead of the correct character. Has anyone seen this
> behavior. I am not sure if it is due to the linux-gpib driver, asyn or
> the Keithley. I plan to put another device on the bus to see if it is
> just this combination. Is anyone out there using this combination?
> Best wishes,
> Stuart
phone:        +49 30 3481 7111
fax:        +49 30 69 3481 7111
eMail:        [email protected]
Postalische Anschrift / mailing address:        |        Besucheranschrift / Visitors address:
Peter Müller        |
in        |
Physikalisch-Technische Bundesanstalt        |        Helmholtzzentrum für Materialien und Energie
O.E. 7.11 Röntgenradiometrie        |        Wilhelm-Conrad-Röntgen Campus
Abbestraße 2-12        |        Albert-Einstein-Straße 15
D-10587 Berlin        |        12489 Berlin
Prev: RE: pyepics: Strategies for working with fast-changing large arrays Mark Rivers
Next: porting strategy from IDL Paul Sichta
Prev: Re: linux-gpib with asyn Dirk Zimoch
Next: Any CAMAC users left? Paul Sichta
