Hi All, Hopefully attached, is a copy of a EPICS Galil driver that uses the motor Record. The driver is updated regularly, so for now, contact me by email for updates. Soon we will have a website for public access. So far the driver has worked on all Galil units tested, which includes the following models: 1415 21X3 Series 40x0 Series RIO Series The driver uses a config/MASTER_RELEASE build mechansim identical to that used in synApps 5_2, to assist in building the required support modules. An example config/MASTER_RELEASE, and config/Makefile file is also attached. An example application is included, and the documentation is mainly in the example st.cmd. Email bugs reports to me. Cheers, Mark Clift. Dr. Mark Clift Senior Controls Engineer Australian Synchrotron 800 Blackburn Road Clayton 3168 Ph: +613 8540 4264 Fax: +613 8540 4200 Mail: [email protected]<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you. Attachment:
galil_1-4.tar.gz Attachment:
Makefile Attachment:
MASTER_RELEASE
ANJ, 18 Nov 2013 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
