1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Motor record support for Galil DMC-2183
To: TechTalk EPICS <[email protected]>
Date: Thu, 26 Jan 2012 10:57:21 -0800
Who knew ;-)
Your mail to 'Tech-talk' with the subject
Is being held until the list moderator can review it for approval.
The reason it is being held:
   Message body is too big: 18558715 bytes with a limit of 256 KB
Phil, I hope you received the previous message in your direct mailbox.
If not, give me access to a FTP site.
Emmanuel
On Thu, Jan 26, 2012 at 10:41 AM, Emmanuel Mayssat <[email protected]> wrote:
> See attached.
> Note: It was not packaged for redistribution, but all the parts are there.
> It is just a tar-ball of my dmc2183 driver source directory.
> Enjoy,
> Emmanuel
> On Mon, Jan 23, 2012 at 6:03 AM, Phillip Sorensen <[email protected]> wrote:
>> Hello,
>> I see references to support for Galil motor drivers, but I have not found
>> links to any code.  Does anyone has device support (specifically for the
>> motor record) for the Galil DMC-2183 or similar unit.
>> Thanks,
>> Phil Sorensen
Motor record support for Galil DMC-2183 Phillip Sorensen
Prev: RE: Motor record support for Galil DMC-2183 Mark Clift
Next: Struck SIS3302 device driver Chengcheng Xu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Motor record support for Galil DMC-2183 Mark Rivers
Next: Re: Motor record support for Galil DMC-2183 Mark Clift
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
