Subject: RE: mvme6100 HW issues?
To: Vesna Samardzic-Boban <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 2 Feb 2012 11:04:52 -0800
Hi Vesna,
Unfortunately, if the boards aren't under warranty the repair is expensive.
Good luck.
- Regards,
  Kristi
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Vesna Samardzic-Boban
Sent: Wednesday, February 01, 2012 11:05 PM
To: [email protected]
Thank you all who replied, for your very good descriptions/reports on the board failures.
I am surprised with the board's failure rate.
Your advices about the board/ crate/ cooling/ EMI stripes etc. are really helpfull.
Hope they will repair / replace the board quickly (it's under warranty).
Vesna
Sent: Thursday, 2 February 2012 5:38 AM
To: Allison, Stephanie; Vesna Samardzic-Boban; [email protected]
Yes, we had the same problem in lcls. A some point the boards were manufactured such that that the bottom of the board would catch on the emi strip.
We even had components ripped off or loosened. It was a mess. So we talked to the vendor about adding a film cover on the bottom of these boards, and
In the meantime we did as Stephanie has done, removed the EMI strip on the VME crates to solve our problem.  So far nothing more has been done with the
Additional film strip on the bottom of these boards.
- Kristi
From: [email protected] [mailto:[email protected]] On Behalf Of Allison, Stephanie
Sent: Wednesday, February 01, 2012 8:39 AM
To: Vesna Samardzic-Boban; [email protected]
Hi Vesna,
At SSRL/SPEAR, we had a high failure rate for our MVME6100 boards until we pulled all EMI stripes off our Wiener VME crates.  The boards were repaired by the manufacturer.
Stephanie Allison
> Sent: Tuesday, January 31, 2012 10:47 PM
> Subject: mvme6100 HW issues?
> Hi,
> Has anyone experienced HW issues with MVME6100 board (or any other MVME board)?
> Recently we bought our first Motorola/Emerson MVME6100 board.
> It worked fine for about a couple of months but then it would start to show errors and stop
> working (unresponsive).
> As nothing was changed in the HW setup (only that board in the crate, the crate open, the
> fan ok, etc.), and the errors caught on the screen looked like given below, I believe it could
> be a HW fault.
> Some of the errors caught on the screen:
> MVME6100>
> isr: CPU Bus Parity Error
> isr: Reg0x78 = 000001f0, Address = 002d6ab8
> isr: Data High:Low = 00000000:00000000
> isr: Parity = df, Cause = 30000040
> After the screen freezes, it is not possible to enter anything from the keyboard.
> It happens regardless of the way i boot i.e. for both MOTLoad FW (S4 = off on on off) or
> vxWorks (S4 = off off off off).
> I noticed the heatsink on the board is loose and possibly not mounted properly (also would
> get very hot) - so I just sent it back to the supplier/manufacturer.
> Has anyone experienced similar problems with mvme6100 or any other mvme board?
> Regards, Vesna<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
mvme6100 HW issues? Vesna Samardzic-Boban
RE: mvme6100 HW issues? Allison, Stephanie
RE: mvme6100 HW issues? Luchini, Kristi L.
RE: mvme6100 HW issues? Vesna Samardzic-Boban
Prev: RE: mvme6100 HW issues? Vesna Samardzic-Boban
Next: RE: mcaR7-0 Szalata, Zenon M.
Next: Re: mvme6100 HW issues? chris.colborne
