Hi Pavel,
This error
ERROR: vxi11Configure is not supported on WIN32
is expected because there is no support for VXI-11 on win32-x86, because we don't have an implementation of Sun RPC for win32-x86, which the VXI-11 support requires.
However, this error:
drvAsynIPPortConfigure("L0", "172.20.92.3", 0, 0, 0)
st.cmd -- Line 50 -- Command drvAsynIPPortConfigure not found.
is not expected. The drvAsynIPPortConfigure command works fine on win32-x86. You must have a mistake in building your application, perhaps you forgot to include "drvAsynIPPort.dbd" in your dbd file.
From: [email protected] [[email protected]] on behalf of Pavel Masloff [[email protected]]
Sent: Monday, March 05, 2012 8:31 AM
To: EPICS Tech Talk; Nicholas P. DiMonte
Subject: TDS 3000 on win32-x86
Hi Nick et al. :
I am trying to use your Tektronix TDS-3000 support on win32-x86. And I have found that it neither works via "Direct network connection" nor "GPIB/LAN connection":
Is there a possibility to talk to the TDS 3054C device any other way on win32? If so, could you give me a hint?
If using "Remote serial port", the following errors occur:
asynOctetSetInputEos("L0",0,"\n")
Port L0 connectDevice failed: asynManager:connectDevice port L0 not found
asynOctetSetOutputEos("L0",0,"\n")
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
- TDS 3000 on win32-x86 Pavel Masloff
Re: Problems with priorities in epicsThreadCreate: Thank you. Goetz Pfeiffer
<2012>
<2012>
