For I/O redirection to work a source file must include epicsStdioRedirect.h.
It's likely that lots of support modules and drivers have not yet done so.
On Mar 13, 2012, at 2:11 PM, Allison, Stephanie wrote:
> Hello,
> When using redirection of output to a file in iocshCmd where the command is one that calls report functions via function pointer like dbior:
> iocshCmd("dbior > /dat/dbiorOutput")
> the output file contains only the output (printf) from the dbior routine itself but not output (printf) from each driver (called using a function pointer in drvet).
> Is this a limitation of the iocsh, mixing C and C++, or the non-thread-safeness (as advertised in the app dev guide) of iocshCmd? Or am I doing something else wrong? It happens on linux-x86_64, RTEMS 4.9.4, and vxWorks 5.4.
> Thank you,
> Stephanie Allison
Eric Norum
[email protected]
- RE: iocshCmd, redirection, and function pointers Mark Rivers
- Re: iocshCmd, redirection, and function pointers Dirk Zimoch
- iocshCmd, redirection, and function pointers Allison, Stephanie
Re: SmarAct / SmarPod Ernest L. Williams Jr.
<2012>
2025
<2012>
2025
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
