Subject: Re: iocshCmd, redirection, and function pointers
To: Eric Norum <[email protected]>
Date: Wed, 14 Mar 2012 11:12:08 +0100
Eric Norum wrote:
For I/O redirection to work a source file must include epicsStdioRedirect.h.
This sucks.
It this is the case, I would say that there is something wrong with the EPICS redirection. Code should not need to know about its "environment". This contradicts any good programming practice.
Dirk
It's likely that lots of support modules and drivers have not yet done so.
On Mar 13, 2012, at 2:11 PM, Allison, Stephanie wrote:
Hello,
When using redirection of output to a file in iocshCmd where the command is one that calls report functions via function pointer like dbior:
iocshCmd("dbior > /dat/dbiorOutput")
the output file contains only the output (printf) from the dbior routine itself but not output (printf) from each driver (called using a function pointer in drvet).
Is this a limitation of the iocsh, mixing C and C++, or the non-thread-safeness (as advertised in the app dev guide) of iocshCmd?  Or am I doing something else wrong?  It  happens on linux-x86_64, RTEMS 4.9.4, and vxWorks 5.4.
Thank you,
Stephanie Allison
Re: iocshCmd, redirection, and function pointers Eric Norum
iocshCmd, redirection, and function pointers Allison, Stephanie
Prev: sysBusToLocalAdrs question Bai Jiaoni
Next: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
Prev: RE: iocshCmd, redirection, and function pointers Mark Rivers
Next: Re: iocshCmd, redirection, and function pointers Eric Norum
