Subject: asyn w/serial device pushing data
Date: Mon, 2 Apr 2012 12:16:35 -0700
I'd like to use asynPortDriver to connect to a serial device that pushes data when triggered by a hardware pulse.
If I use SCAN=I/O Intr and the pollThread() example code below from a previous tech-talk thread will my record be triggered to read every time there is new data?  Does this code mean my driver is constantly polling the serial port at a POLL_DELAY?
I only need to read, so can I call pasynOctetSyncIO->readIt() instead?
How will I know that the serial device has finished pushing it's data for that trigger?  Does asyn/pasynOctetSynIO->readIt() wait for the OutputEos in the serial buffer before returning the received message?  Or is asyn waiting to read sizeof(receiveMessage) characters?
> void myPortDriver::pollThread()
>     while(1) {
>           status = pasynOctetSyncIO->writeRead(pasynUserHMS, sendMessage, numSend,
>                                          receiveMessage, sizeof(receiveMessage),
>                                          WRITE_READ_TIMEOUT, &numSent, responseLen, &eomReason);
>           sscanf(receiveMessage, "TEMP=%f,CURRENT=%f", &temperature, &current);
>           setDoubleParam(temperatureParam, temperature);
>           setDoubleParam(currentParam, current);
>           callParamCallbacks();
>           epicsThreadSleep(POLL_DELAY);
Thank you in advance for any suggestions or comments.
Nia
Re: asyn w/serial device pushing data Eric Norum
RE: asyn w/serial device pushing data Mark Rivers
Prev: Re: casStrmClient.cc error: invalid channel identifier Tim Mooney
Next: Re: asyn w/serial device pushing data Eric Norum
Prev: Re: casStrmClient.cc error: invalid channel identifier Andrew Johnson
