Subject: ECHO variable in build rules
To: <[email protected]>
Date: Fri, 27 Apr 2012 15:19:42 +0200
Hi All
CONFIG_COMMON currently contains this snippet:
# Make echo output - suppress echoing if make's '-s' flag is set
COMMENT = \#
ECHO = @$(if $(findstring s,$(patsubst T_A=%,,$(MAKEFLAGS))),
$(COMMENT),echo)
(for win32 COMMENT gets overridden as COMMENT = $(PERL) -e '')
This is a bit dangerous, as it breaks rules that use ';', e.g.
	$(ECHO) Creating foo; ../create-foo.sh > foo
The comment will disable the whole command line, not only the echo command.
This broke one of our self-written build rules and took me and a colleague
almost a whole day to debug.
There is an alternative: The colon (':') can be used as NOP (ignore all
arguments) in all unix shells (including at least dash, bash, and zsh).
So I propose to replace COMMENT with NOP, defining
NOP = ":"
ECHO = @$(if $(findstring s,$(patsubst T_A=%,,$(MAKEFLAGS))),$(NOP),echo)
and on win32 systems
NOP = $(PERL) -e ''
The extra definition for ECHO in RULES.Db is not necessary and should be
removed.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: ECHO variable in build rules Andrew Johnson
Prev: Problem installing EDM on Fedora 16 manta santosh aditya santosh_aditya
Next: Re: [StreamDevice] need advice Pavel Masloff
Next: Re: ECHO variable in build rules Andrew Johnson
