1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: ECHO variable in build rules
To: Benjamin Franksen <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Tue, 1 May 2012 10:59:00 -0500
Hi Ben,
On 2012-04-27 you wrote:
> So I propose to replace COMMENT with NOP, defining
> NOP = ":"
> ECHO = @$(if $(findstring s,$(patsubst T_A=%,,$(MAKEFLAGS))),$(NOP),echo)
> and on win32 systems
> NOP = $(PERL) -e ''
> The extra definition for ECHO in RULES.Db is not necessary and should be
> removed.
Committed, with a patch file available through the Known Problems page.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
ECHO variable in build rules Benjamin Franksen
Prev: RE: [Scopes] BMP image record?? Mark Rivers
Next: RE: [Scopes] BMP image record?? Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: ECHO variable in build rules Benjamin Franksen
Next: [Scopes] BMP image record?? Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
