1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: labCa build fails on 64 bit Windows
Date: Fri, 04 May 2012 10:59:58 -0700
On 05/04/2012 03:44 AM, [email protected] wrote:
Hi Ernest
Please can I have the binaries while I work out what's wrong with the Visual Studio 2010 build, I don't have 2008.
Sure.
I will zip it up and mail it to you.
Or maybe, I should create a static executable?
Cheers,
Ernest
James
-----Original Message-----
From: Ernest L. Williams Jr. [mailto:[email protected]]
Sent: 03 May 2012 22:33
To: Till Straumann
Cc: Rowland, James (DLSLtd,RAL,DIA); [email protected]
On 05/03/2012 09:12 AM, Till Straumann wrote:
I built it on 64-bit windows7 for matlab 2011a. I don't recall what
compiler version
I used MS Visual Studio 2010
I can provide binaries as well. :)
Cheers,
Ernest.
was used. Maybe Ernest can fill us in. He should also have access to
the binaries; if you're lucky they work for you.
- Till
On 05/03/2012 06:06 AM, [email protected] wrote:
Hi
Has anyone got labCa 3.4 to build on windows-64? If so, what
combination of Matlab, Windows and Compiler are you using. I can't
get it to work with Windows Server 2008, MatlabR2011b, Visual Studio
2010, EPICS 3.14.12.1
Initially the build fails building ezcaglue with some missing libraries:
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref
/release   /MACHINE:X64    c:/ma
tlab2011b/extern/lib/win64/microsoft/libut.lib
c:/matlab2011b/extern/lib/win64/microsoft/libmx.lib c
:/matlab2011b/extern/lib/win64/microsoft/libmex.lib  /implib:mezcaglue.lib
/out:mezcaglue.dll
      ini.obj multiEzca.obj ctrlC-polled.obj mglue.obj
..\\..\\lib\\windows-x64\\ezcamt.lib  d:\ep
ics\r3.14.12.1\base\\lib\\windows-x64\\ca.lib
d:\epics\r3.14.12.1\base\\lib\\windows-x64\\Com.lib u ser32.lib
      Creating library mezcaglue.lib and object mezcaglue.exp
ca.lib(ca_client_context.obj) : error LNK2001: unresolved external
symbol __imp_bind etc.
Adding ws2_32 and advapi32 to USR_SYS_LIBS fixes this but the mex functions
fail:
make[2]: Entering directory
`S:/Technical/Controls/Software/Matlab/Build/labca_3_4/matlab/O.windo
ws-
x64'
c:/matlab2011b/bin/mex.bat   -DMATLAB_APP  ../lcaGetNelem.c -I. -
I../O.Common -I. -I.. -I../../inclu
de/os/WIN32 -I../../include -Id:\epics\r3.14.12.1\base/include/os/WIN32 -
nclude         -I../../ezca -I../../glue      ../../lib/windows-
x64/mezcaglue.lib  ../../lib/windows
-x64/ezcamt.lib  d:\epics\r3.14.12.1\base/lib/windows-x64/ca.lib
ws-x64/Com.lib  ../../lib/windows-x64/ezcamt.lib
d:\epics\r3.14.12.1\base/lib/windows-x64/ca.lib  d
:\epics\r3.14.12.1\base/lib/windows-x64/Com.lib ws2_32.lib advapi32.lib
ws2_32.lib advapi32.lib user 32.lib kernel32.lib winmm.lib
      Creating library
C:\Users\jr76\AppData\Local\Temp\3\mex_JqkfYu\templib.x and object
C:\Users\jr76 \AppData\Local\Temp\3\mex_JqkfYu\templib.exp
lcaGetNelem.obj : error LNK2019: unresolved external symbol
__imp_ezcaFree referenced in function me xFunction
lcaGetNelem.mexw64 : fatal error LNK1120: 1 unresolved externals
     C:\MATLAB~1\BIN\MEX.PL: Error: Link of 'lcaGetNelem.mexw64' failed.
make[2]: *** [lcaGetNelem.mexw64] Error 2
make[2]: Leaving directory
ws-x
64'
make[1]: *** [install.windows-x64] Error 2
make[1]: Leaving directory
`S:/Technical/Controls/Software/Matlab/Build/labca_3_4/matlab'
make: *** [matlab.install] Error 2
S:\Technical\Controls\Software\Matlab\Build\labca_3_4>
James
Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
labCa build fails on 64 bit Windows james.rowland
Re: labCa build fails on 64 bit Windows Till Straumann
RE: labCa build fails on 64 bit Windows james.rowland
Prev: Re: [Scopes] BMP image record?? Eric Norum
Next: Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: labCa build fails on 64 bit Windows james.rowland
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
