1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: cPCI express
To: [email protected]
Date: Mon, 14 May 2012 18:39:02 +0200
Hi Michael
Thanks for the reply. Yes I know that from the software side there are not many differences (backwards compatibility and all). I guess that my question was not so clear.
The biggest problem we have is in finding the hardware - simple DAQ boards an so on. There are PXIe boards, but to find a cPCIe multipurpose DAQ board turned out to be quite the challenge. Even for the CPU there are not so many manufacturers (MEN elektronics have cPCIe , than mostly PXIe cpu boards by NI, Adlink, geotest). I know that PXIe can be used as a cPCIe (some additional synchronization features of PXI are lost), but when looking for pure cPCIe the resources seem to be quite limited. So I thought I'd post here, If anyone else has had experience with setting up a cPCIe system (from hardware point of view).
Ursa Rojec
On 05/14/2012 05:38 PM, Michael Davidsaver wrote:
Hello Urša,
When you speak with software developers you may not hear PCIe explicitly mentioned often. For software there is (intentionally) little difference between PCI and PCIe.
In our server systems we use PMC modules with a PMC-PCIe carrier card. This presents a transparent bridge. No software changes were required to accommodate this.
Michael Davidsaver
NSLSII Controls Group
Brookhaven National Lab
On 5/14/2012 5:09 AM, Urša Rojec wrote:
Dear all,
I am looking for comments and suggestions on cPCIe. Do you use any cPCIe modules as part of your contols? Could you tell me the module name, manufacturer?
I have been looking at tech talk and cPCI express is not mentioned. Is nobody using it?
Any help would be appreciated.
U
Re: cPCI express Paul Sichta
cPCI express Urša Rojec
Re: cPCI express Michael Davidsaver
Prev: Re: cPCI express Michael Davidsaver
Next: Re: Regarding access of Process Variable Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: cPCI express Paul Sichta
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
