Subject: Re: cPCI express
To: Urša Rojec <[email protected]>
Cc: [email protected]
Date: Mon, 14 May 2012 13:41:36 -0400
Ursa,
I can confirm your findings, COTS cPCI or cPCIe hardware is very
limited.  The more popular bus standards are VME, PXI(e), PC-104.
I've heard some rumblings about microTCA but haven't seen any
products.
Not sure what type of hardware you're after.  We've used cPCI
transient digitizers by D-Tacq, (not in EPICS but it has limited EPICS
support). You might look for cPCI carrier boards, then you can use PMC
or IndustryPack I/O boards.
-ps
On Mon, May 14, 2012 at 12:39 PM, Urša Rojec <[email protected]> wrote:
> Hi Michael
> Thanks for the reply. Yes I know that from the software side there are not
> many differences (backwards compatibility and all). I guess that my question
> was not so clear.
> The biggest problem we have is in finding the hardware - simple DAQ boards
> an so on. There are PXIe boards, but to find a cPCIe multipurpose DAQ board
> turned out to be quite the challenge. Even for the CPU there are not so many
> manufacturers (MEN elektronics have cPCIe , than mostly PXIe cpu boards by
> NI, Adlink, geotest). I know that PXIe can be used as a cPCIe (some
> additional synchronization features of PXI are lost), but when looking for
> pure cPCIe the resources seem to be quite limited. So I thought I'd post
> here, If anyone else has had experience with setting up a cPCIe system (from
> hardware point of view).
> Ursa Rojec
> On 05/14/2012 05:38 PM, Michael Davidsaver wrote:
>> Hello Urša,
>> When you speak with software developers you may not hear PCIe explicitly
>> mentioned often.  For software there is (intentionally) little difference
>> between PCI and PCIe.
>> In our server systems we use PMC modules with a PMC-PCIe carrier card.
>>  This presents a transparent bridge.  No software changes were required to
>> accommodate this.
>> Michael Davidsaver
>> NSLSII Controls Group
>> Brookhaven National Lab
>> On 5/14/2012 5:09 AM, Urša Rojec wrote:
>>> Dear all,
>>> I am looking for comments and suggestions on cPCIe. Do you use any cPCIe
>>> modules as part of your contols? Could you tell me the module name,
>>> manufacturer?
>>> I have been looking at tech talk and cPCI express is not mentioned. Is
>>> nobody using it?
>>> Any help would be appreciated.
>>> U
Re: cPCI express Urša Rojec
Re: cPCI express Michael Davidsaver
Prev: Re: Regarding access of Process Variable Hinko Kocevar
Next: Re: Channel Access monitoring tools Bill Lavender
Prev: Re: cPCI express Urša Rojec
Next: Re: cPCI express Urša Rojec
