Subject: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms"
To: 洪春霞 <[email protected]>
Cc: [email protected]
Date: Thu, 24 May 2012 16:30:44 +0200
Dirk Zimoch wrote:
> I don't see where you set the baud rate. Use something like
> asynSetOption ("MOXA1", 0, "baud", "9600")
Well, this won't work. It works only if the Moxa maps its serial lines
to local /dev/ttyXXX devices on your PC and you use it like a local
serial line.
With the TCP connection, you may need a different way to set the baud
rate. I don't know how. See the Moxa manual.
Dirk
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
"@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" 洪春霞
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Dirk Zimoch
Prev: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Dirk Zimoch
Next: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
