Subject: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms"
To: Dirk Zimoch <[email protected]>
Cc: 洪春霞 <[email protected]>, [email protected]
Date: Thu, 24 May 2012 08:37:07 -0700
Serial port parameter changes of a LAN/Serial adapter will work if
a) Your LAN/Serial adapter supports 'RFC2217' operation (most do -- check the adapter manual for details)
and
b) you're using ASYN R4-16 or better
and
c) you add 'COM' to the port configuration line -- drvAsynIPPortConfigure("MOXA1","192.168.127.254:4001 COM",0,0,0)
On May 24, 2012, at 7:30 AM, Dirk Zimoch wrote:
> Dirk Zimoch wrote:
>> I don't see where you set the baud rate. Use something like
>> asynSetOption ("MOXA1", 0, "baud", "9600")
> Well, this won't work. It works only if the Moxa maps its serial lines
> to local /dev/ttyXXX devices on your PC and you use it like a local
> serial line.
> With the TCP connection, you may need a different way to set the baud
> rate. I don't know how. See the Moxa manual.
> Dirk
Eric Norum
[email protected]
"@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" 洪春霞
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Dirk Zimoch
Prev: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Dirk Zimoch
Next: RE: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Mark Rivers
