Subject: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms"
To: Eric Norum <[email protected]>
Cc: 洪春霞 <[email protected]>, epics Talk <[email protected]>
Date: Fri, 25 May 2012 09:34:59 +0200
Eric Norum wrote:
I'm actually kind of surprised that StreamDevice 2-5 (the latest, right?) even works with ASYN from over five years ago.
With every change in StreamDevice I am very careful not to break compatibility with earlier versions of asyn and base. You can run the current StreamDevice version with asyn 4-6 and base 3.14.7 (or even 3.13.9 with some tricks) if you like. Sometimes I wish other people would spend that effort too.
Dirk
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Andrew Johnson
"@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" 洪春霞
RE: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Mark Rivers
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
Prev: Re: medm and Xming on Windows 7 64 bit Pavel Masloff
Next: [NI] PXI 1000 EPICS support ? Pavel Masloff
Prev: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
Next: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Andrew Johnson
