Subject: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms"
To: [email protected]
Cc: Eric Norum <[email protected]>
Date: Fri, 25 May 2012 11:07:29 -0500
Hi Dirk,
On 2012-05-25 Dirk Zimoch wrote:
> Eric Norum wrote:
> > I'm actually kind of surprised that StreamDevice 2-5 (the latest, right?)
> > even works with ASYN from over five years ago.
> With every change in StreamDevice I am very careful not to break
> compatibility with earlier versions of asyn and base. You can run the
> current StreamDevice version with asyn 4-6 and base 3.14.7 (or even
> 3.13.9 with some tricks) if you like. Sometimes I wish other people
> would spend that effort too.
I regard new features and bug fixes as an incentive to get people to upgrade
their IOCs to newer versions of Base.  Otherwise we have to continue to
support ancient versions of the code, and they keep hitting old bugs.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: "@init handler failed" , "Record initialization failed" and "No reply fro device within 1000 ms" J. Lewis Muir
"@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" 洪春霞
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Dirk Zimoch
Prev: RE: [NI] PXI 1000 EPICS support ? Mark Rivers
Next: Re: "@init handler failed" , "Record initialization failed" and "No reply fro device within 1000 ms" J. Lewis Muir
Prev: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Dirk Zimoch
