Subject: Re: calc VAL field not updating from bi VAL field
Cc: [email protected]
Date: Wed, 30 May 2012 16:45:22 -0500
On 5/30/12 4:33 PM, Andrew Johnson wrote:
> Are you cross-compiling Base on a Linux or Solaris host?  Please post the
> output from running 'ccppc -v' so I know which compiler you're using.
Hi, Andrew.
I'm cross-compiling on a Linux host.
Here's the output you requested:
$ /opt/vxworks-tornado-2.2.2/ppc/host/x86-linux/bin/ccppc -v
Reading specs from
/opt/vxworks-tornado-2.2.2/ppc/host/x86-linux/bin/../lib/gcc-lib/powerpc-wrs-vxworks/gcc-2.96/specs
gcc version gcc-2.96 (2.96+) 19990621 AltiVec
(This is the compiler provided on APSshare at vw/tornado22-ppc.)
Lewis
Re: calc VAL field not updating from bi VAL field Andrew Johnson
calc VAL field not updating from bi VAL field J. Lewis Muir
Re: calc VAL field not updating from bi VAL field Tim Mooney
RE: calc VAL field not updating from bi VAL field Mark Rivers
Prev: RE: calc VAL field not updating from bi VAL field Mark Rivers
Next: Re: Proposed change in asyn - request for comments Bruce Hill
Next: Re: calc VAL field not updating from bi VAL field Andrew Johnson
