Hi Eric,
On 2012-05-30 Eric Norum wrote:
> Actually the asyn devEpics layer is simpler than described above.
> - It always sets the record TIME field from the pasynUser->timestamp in
> the device support interrupt callback or read method then returns to
> higher level record processing code.
> - The record processing code then
> overwrites the TIME field unless the TSE field is -2.
If you do this it is possible for a client that is doing ca_get operations (or
even some other record that might have its TSEL pointing to this record's TIME
field) to see the time set by the devEpics layer, even if the record
subsequently overwrites the TIME field. Since the TIME field is a structure
with two 32-bit components it is even possible for such a client or record to
see the seconds part of the old time-stamp and the nanoseconds from the new
one (or vice-versa) if the interrupt happened to occur in between it reading
the two parts.
I suspect some of them do, but I don't think device support should be updating
*any* publicly visible record fields from inside an ISR, since it can't be
sure that the record isn't currently locked and having field values being read
out of it.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: Proposed change in asyn - request for comments Eric Norum
- Proposed change in asyn - request for comments Mark Rivers
- RE: Proposed change in asyn - request for comments Kim, Kukhee
Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Re: [CSS] commas in TextUpdate Pavel Masloff
<2012>
2025
<2012>
2025
