Subject: Re: Proposed change in asyn - request for comments
Cc: [email protected]
Date: Thu, 31 May 2012 08:42:59 -0700
On May 31, 2012, at 8:08 AM, Andrew Johnson wrote:
> Hi Eric,
> On 2012-05-30 Eric Norum wrote:
>> Actually the asyn devEpics layer is simpler than described above.
>> - It always sets the record TIME field from the pasynUser->timestamp in
>> the device support interrupt callback or read method then returns to
>> higher level record processing code.
>> - The record processing code then
>> overwrites the TIME field unless the TSE field is -2.
> If you do this it is possible for a client that is doing ca_get operations (or
> even some other record that might have its TSEL pointing to this record's TIME
> field) to see the time set by the devEpics layer, even if the record
> subsequently overwrites the TIME field.  Since the TIME field is a structure
> with two 32-bit components it is even possible for such a client or record to
> see the seconds part of the old time-stamp and the nanoseconds from the new
> one (or vice-versa) if the interrupt happened to occur in between it reading
> the two parts.
> I suspect some of them do, but I don't think device support should be updating
> *any* publicly visible record fields from inside an ISR, since it can't be
> sure that the record isn't currently locked and having field values being read
> out of it.
Who said that we were doing this from an ISR?
I guess that I wasn't clear enough.    The devEPICS code that's writing to the .TIME field is actually in an interrupt callback thread -- at task-level.
This is acceptable isn't it?
Eric Norum
[email protected]
Re: Proposed change in asyn - request for comments Andrew Johnson
Proposed change in asyn - request for comments Mark Rivers
RE: Proposed change in asyn - request for comments Kim, Kukhee
Re: Proposed change in asyn - request for comments Eric Norum
Prev: Re: errro running "ibtest" Rod Nussbaumer
Next: Re: [StreamDevice] parsing rapid inputs Dirk Zimoch
Prev: Re: Proposed change in asyn - request for comments Andrew Johnson
Next: Re: Proposed change in asyn - request for comments Andrew Johnson
