Subject: Re: counter of clients for specific PV in IOC
To: [email protected]
Date: Tue, 5 Jun 2012 10:11:02 -0500
Hi Yingbing,
On 2012-06-04 Yingbing Yan wrote:
> Is there a function to get the counter of clients for specific PV?
> Such as:
> void casStatsFetch ( unsigned *pChanCount, unsigned *pConnCount );
> Using this function, we can only monitor the clients of the whole ioc
> rather than some channel.
There is an iocsh command 'dbel' which displays that information for all the
fields of a named record, but unfortunately no function you can call to fetch
that information directly from your code:
epics> help dbel
dbel 'record name' level
epics> dbel
epics> dbel anj:exit
1 PV Event Subscriptions ( monitors ).
epics> dbel anj:exit 1
 VAL { VALUE ALARM }
epics> dbel anj:exit 2
 VAL { VALUE ALARM }, thread=0x7f470c0095d0, queue empty
A subroutine record can get the number of clients that are monitoring its own
fields using the expression
    prec->mlis.count
A subroutine can do this because the record's lock-set is locked while the
record is processed and the subroutine is called; if you wanted to access that
field outside of the subroutine you would need to lock the record's lock-set
first using dbScanLock(prec) and dbScanUnlock(prec).
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
counter of clients for specific PV in IOC Yingbing Yan
Prev: RE: a MEDM replacement Mark Rivers
Next: Re: mask for bitwise operation in CALC record Eric Norum
Prev: counter of clients for specific PV in IOC Yingbing Yan
Next: ASYN 4-19 createParam return status Hinko Kocevar
