Subject: Re: mask for bitwise operation in CALC record
To: Dirk Zimoch <[email protected]>
Date: Tue, 5 Jun 2012 08:27:13 -0700
On Jun 5, 2012, at 6:11 AM, Dirk Zimoch wrote:
I think adding something like this to epicsStrtod should fix the problem:
if (epicsStrnCaseCmp("0x", cp, 2) == 0) {
 return (double)strtoul(str, endp, 16);
The code with that change doesn't completely match the semantics of strtod as presented in the C99 standard, but it's certainly better than the current code.
BTW -- does vxWorks still not supply a working strtod?  I think that it is the only system that doesn't just define epicsStrtod as strtod.
Eric Norum
[email protected]
Re: mask for bitwise operation in CALC record Andrew Johnson
mask for bitwise operation in CALC record haquin
Re: mask for bitwise operation in CALC record Dirk Zimoch
Prev: Re: counter of clients for specific PV in IOC Andrew Johnson
Next: Re: mask for bitwise operation in CALC record Andrew Johnson
Prev: Re: mask for bitwise operation in CALC record Dirk Zimoch
