1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: mask for bitwise operation in CALC record
To: [email protected]
Cc: Eric Norum <[email protected]>
Date: Tue, 5 Jun 2012 11:46:06 -0500
Hi Eric,
On Jun 5, 2012, at 6:11 AM, Dirk Zimoch wrote:
> I think adding something like this to epicsStrtod should fix the problem:
> if (epicsStrnCaseCmp("0x", cp, 2) == 0) {
>  return (double)strtoul(str, endp, 16);
I'll be using strtol() instead in the 3.15 code, so -0x1 works.
On 2012-06-05 Eric Norum wrote:
> The code with that change doesn't completely match the semantics of strtod
> as presented in the C99 standard, but it's certainly better than the
> current code.
What else are we missing?  I don't have the C99 standard to look at here.
> BTW -- does vxWorks still not supply a working strtod?  I
> think that it is the only system that doesn't just define epicsStrtod as
> strtod.
The wording in the vxWorks 6.8 manpage is exactly the same as Dirk posted from
vxWorks 5.5.
No, we use our version of epicsStrtod() on Windows, Cygwin, vxWorks and
Solaris.  I have a branch for 3.15 where I've been working on the numeric
conversions, I'll add some tests for the native strtod().
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: mask for bitwise operation in CALC record Eric Norum
mask for bitwise operation in CALC record haquin
Re: mask for bitwise operation in CALC record Dirk Zimoch
Prev: Re: mask for bitwise operation in CALC record Eric Norum
Next: Re: mask for bitwise operation in CALC record Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
