All,
I am attempting to build EPICS 3.14.12.2 on a Windows XP machine using mingw32.
EPICS_HOST_ARCH = win32-x86-mingw
I type”make” at the top level directory (c:\epics). Make is GNU Make version 3.81
I get an error: /bin/ld.exe: cannot find -lrtemscpu
The closest matching file I have on my machine is librtemscpu.a.
What is lrtemscpu? Do I need to build a separate package to generate it?
Any help much appreciated.
- Yoram Fisher –
make[3]: Entering directory `/c/epics/src/libCom/test/O.win32-x86-mingw'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/c/epics/src/libCom/test/O.win32-x86-mingw'
make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../../.. T_A=RTEMS-uC5282 install
make[3]: Entering directory `/c/epics/src/libCom/test/O.RTEMS-uC5282'
/c/opt/rtems-4.10/bin/m68k-rtems4.10-g++ -o rtemsTestHarness -static -L/c/epics/
lib/RTEMS-uC5282 -mcpu=5282 -u Init /lib/no-dpmem.rel /lib/no-mp.rel /li
b/no-part.rel /lib/no-signal.rel /lib/no-rtmon.rel rtemsTestHarness.o
epicsCalcTest.o epicsAlgorithmTest.o epicsMathTest.o epicsEllTest.o epicsErrlog
Test.o epicsStdioTest.o epicsStringTest.o epicsTimeTest.o epicsThreadTest.o epic
sThreadOnceTest.o epicsThreadPriorityTest.o epicsThreadPrivateTest.o epicsExitTe
st.o epicsTimerTest.o ringPointerTest.o ringBytesTest.o epicsEventTest.o epicsMu
texTest.o epicsExceptionTest.o macEnvExpandTest.o macLibTest.o taskwdTest.o bloc
kingSockTest.o epicsMessageQueueTest.o epicsRunLibComTests.o epicsThreadPerform.
o epicsMaxThreads.o buckTest.o cvtFastPerform.o -lCom -lm -lrtemsCom -l
c -lrtemscpu -lCom -lnfs -lm
c:/opt/rtems-4.10/bin/../lib/gcc/m68k-rtems4.10/4.4.7/../../../../m68k-rtems4.10
collect2: ld returned 1 exit status
make[3]: *** [rtemsTestHarness] Error 1
make[3]: Leaving directory `/c/epics/src/libCom/test/O.RTEMS-uC5282'
make[2]: *** [install.RTEMS-uC5282] Error 2
make[2]: Leaving directory `/c/epics/src/libCom/test'
make[1]: *** [libCom/test.install] Error 2
make[1]: Leaving directory `/c/epics/src'
make: *** [src.install] Error 2
Yoram Fisher
Senior Systems Engineer
Sydor Instruments, LLC
291 Millstead Way
Rochester, New York 14624
Ph: +1.585.278.1168, Fax: +1.585.278.1169
Email:
[email protected]
web:
www.sydorinstruments.com
