Subject: Re: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw
To: Yoram Fisher <[email protected]>
Date: Thu, 7 Jun 2012 08:34:02 -0700
Sorry to have been confused by your original message.  I didn't realize that you really did want to cross-compile.
RTEMS tools, core and board-support packages are all available as RPM files with support for APT or Yum.
I know that RTEMS/EPICS for the uC5282 builds without problems  on a LInux (or OS X) platform.
Here's what the build output near the link command for the EPICS libCom test harness looks like on my machine:
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-gcc --pipe -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/ -specs bsp_specs -qrtems   -fasm -c   -mcpu=5282              -DUNIX     -O2 -g -g  -Wall      -DMY_DO_BOOTP=NULL      -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/RTEMS -I../../../../include        ../epicsMaxThreads.c
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-gcc --pipe -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/ -specs bsp_specs -qrtems   -fasm -c   -mcpu=5282              -DUNIX     -O2 -g -g  -Wall      -DMY_DO_BOOTP=NULL      -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/RTEMS -I../../../../include        ../buckTest.c
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/ -specs bsp_specs -qrtems   -c   -mcpu=5282              -DUNIX     -O2 -g -g  -Wall      -DMY_DO_BOOTP=NULL     -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/RTEMS -I../../../../include        ../cvtFastPerform.cpp
../cvtFastPerform.cpp: In member function 'void Test::execute()':
../cvtFastPerform.cpp:63: warning: integer overflow in expression
../cvtFastPerform.cpp:65: warning: integer overflow in expression
../cvtFastPerform.cpp:75: warning: integer overflow in expression
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/ -specs bsp_specs -qrtems   -o rtemsTestHarness -static -L/usr/local/epics/R3.14.12/base-3.14.12.2/lib/RTEMS-uC5282         -mcpu=5282 -u Init /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-dpmem.rel /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-mp.rel /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-part.rel /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-signal.rel /usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/no-rtmon.rel            rtemsTestHarness.o epicsCalcTest.o epicsAlgorithmTest.o epicsMathTest.o epicsEllTest.o epicsErrlogTest.o epicsStdioTest.o epicsStringTest.o epicsTimeTest.o epicsThreadTest.o epicsThreadOnceTest.o epicsThreadPriorityTest.o epicsThreadPrivateTest.o epicsExitTest.o epicsTimerTest.o ringPointerTest.o ringBytesTest.o epicsEventTest.o epicsMutexTest.o epicsExceptionTest.o macEnvExpandTest.o macLibTe!
 st.o taskwdTest.o blockingSockTest.o epicsMessageQueueTest.o epicsRunLibComTests.o epicsThreadPerform.o epicsMaxThreads.o buckTest.o cvtFastPerform.o    -lCom       -lm -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-objcopy -O binary -R .comment -S rtemsTestHarness rtemsTestHarness.boot
echo "Installing created file ../../../../bin/RTEMS-uC5282/rtemsTestHarness"
echo "Installing created file ../../../../bin/RTEMS-uC5282/rtemsTestHarness.boot"
make -C db/test install
Eric Norum
[email protected]
EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Yoram Fisher
Re: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Andrew Johnson
RE: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Yoram Fisher
Prev: RE: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Yoram Fisher
Next: error: Command drvAsynIPPortConfigure not found Chen Xue
