Subject: Re: subArray problem
To: [email protected]
Date: Mon, 18 Jun 2012 10:33:17 -0500
Hi Steve,
On 2012-06-18 Steve Hunt wrote:
> When I create a subArray record with MALM set to 1 (which is the
> default),  If I try to change the INDX field - INDX field gets reset to
> 0 !!!!
Sorry, that's the expected behariour...
> With another value of MALM, everything works as expected.
The MALM field defines the maximum number of elements that the subarray can
fetch through its INP link.  If you don't change it or you make it negative,
that maximum will be 1.  What you probably don't realize is that the subArray
record works by fetching up to MALM elements from its source link, then
deleting the first INDX elements from the beginning of the fetched dataset.
It has to do it that way because the Channel Access and Database Access
routines that it uses to fetch the input link do not provide an API that says
"fetch me this many elements starting at this offset"; the record has to make
do with the "fetch me this many elements" routine.  As a result your
subArray.MALM value has to be large enough to cover the largest number of
elements you want plus the largest index.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
subArray problem Steve Hunt
Prev: subArray problem Steve Hunt
Next: ASYN devEpics output record initialization Eric Norum
