Subject: subArray problem
To: [email protected]
Date: Mon, 18 Jun 2012 16:12:38 +0200
When I create a subArray record with MALM set to 1 (which is the
default),  If I try to change the INDX field - INDX field gets reset to
0 !!!!
With another value of MALM, everything works as expected.
I am using 3.14.12.2, and have also tried with 3.14.12 with the same
result
Re: subArray problem Andrew Johnson
Prev: RE: Problem with EPICS c# Library Version 1.2.0.0 Bertrand Alain Gregor
Next: Re: subArray problem Andrew Johnson
Prev: Has anyone built SynApps under minGW? S. Stein
