Subject: RE: Problem with EPICS c# Library Version 1.2.0.0
To: 张玉亮 <[email protected]>, <[email protected]>
Date: Mon, 18 Jun 2012 14:15:06 +0200
Updated the download page:
http://gfa-it.web.psi.ch/epicsSharp/index.php?site=download
Will update the documentation in the coming days.
Sincerely,
Alain Bertrand
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of ???
Sent: Friday, June 15, 2012 11:56
To: [email protected]
Subject: Problem with EPICS c# Library Version 1.2.0.0
Hi all,
One problem confused me with the C# EPICS server using C# library Version 1.2.0.0. I tried to set value directly to Record from C# code, then i used caget to get the pv value, i found that the Record value was always 0 even if i have set Record value to 25. But the version before 1.2.0.0is OK! The following is my code and test:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using PSIEpics;
namespace sharpServer
    class Program
        static void Main(string[] args)
            EpicsServer Server = new EpicsServer();
            //create a new Record which serves a double
            EpicsRecord<double> cpuRecord =Server.GetEpicsRecord<double>("PV:TEST");
            //set HIGH-Alarm
            cpuRecord.HIGH = 50;
            //set HIGH-Alert
            cpuRecord.HIHI = 75;
            //set PV value
            cpuRecord.VAL = 25;
            Console.ReadKey();
[zhangyl@timinglinux2~]$ caget PV:TEST
PV:TEST                         0
Reagards,
Zhang Yuliang
Problem with EPICS c# Library Version 1.2.0.0 张玉亮
Prev: Has anyone built SynApps under minGW? S. Stein
Next: subArray problem Steve Hunt
Prev: Re: Problem with EPICS c# Library Version 1.2.0.0 Alain Bertrand
Next: Has anyone built SynApps under minGW? S. Stein
