Subject: Problem with EPICS c# Library Version 1.2.0.0
To: [email protected]
Date: Fri, 15 Jun 2012 17:56:11 +0800 (CST)
Hi all,
One problem confused me with the C# EPICS server using C# library Version 1.2.0.0. I tried to set value directly to Record from C# code, then i used caget to get the pv value, i found that the Record value was always 0 even if i have set Record value to 25. But the version before 1.2.0.0is OK! The following is my code and test:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using PSIEpics;
namespace sharpServer
    class Program
        static void Main(string[] args)
            EpicsServer Server = new EpicsServer();
            //create a new Record which serves a double
            EpicsRecord<double> cpuRecord =Server.GetEpicsRecord<double>("PV:TEST");
            //set HIGH-Alarm
            cpuRecord.HIGH = 50;
            //set HIGH-Alert
            cpuRecord.HIHI = 75;
            //set PV value
            cpuRecord.VAL = 25;
            Console.ReadKey();
[zhangyl@timinglinux2~]$ caget PV:TEST
PV:TEST                         0
Reagards,
Zhang Yuliang
Re: Problem with EPICS c# Library Version 1.2.0.0 Alain Bertrand
RE: Problem with EPICS c# Library Version 1.2.0.0 Bertrand Alain Gregor
Prev: RE: Problems with areaDetector Prosilica driver on Windows? Mark Rivers
Next: Re: Problem with EPICS c# Library Version 1.2.0.0 Alain Bertrand
Prev: Re: streamdevice: error handling for multiple lines of input from one command Dirk Zimoch
