Subject: Re: Problem with EPICS c# Library Version 1.2.0.0
To: 张玉亮 <[email protected]>
Cc: [email protected]
Date: Fri, 15 Jun 2012 21:01:00 +0200
Hi Zhang Yuliang,
The C# Epics server included in the C# client is not anymore supported as we built a new library just for the server part. That part (as well as the prototype gateway) should be removed from the client library.
On Monday I will send you a link with the code (and I should actually update our webpages).
Sincerely,
Alain Bertrand
On 15/06/2012 11:56, 张玉亮 wrote:
Hi all,
One problem confused me with the C# EPICS server using C# library Version 1.2.0.0. I tried to set value directly to Record from C# code, then i used caget to get the pv value, i found that the Record value was always 0 even if i have set Record value to 25. But the version before 1.2.0.0is OK! The following is my code and test:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using PSIEpics;
namespace sharpServer
     class Program
         static void Main(string[] args)
             EpicsServer Server = new EpicsServer();
             //create a new Record which serves a double
             EpicsRecord<double>  cpuRecord =Server.GetEpicsRecord<double>("PV:TEST");
             //set HIGH-Alarm
             cpuRecord.HIGH = 50;
             //set HIGH-Alert
             cpuRecord.HIHI = 75;
             //set PV value
             cpuRecord.VAL = 25;
             Console.ReadKey();
[zhangyl@timinglinux2~]$ caget PV:TEST
PV:TEST                         0
Reagards,
Zhang Yuliang
Problem with EPICS c# Library Version 1.2.0.0 张玉亮
Prev: Problem with EPICS c# Library Version 1.2.0.0 张玉亮
Next: Re: thermocouple solutions Wesley Moore
Next: RE: Problem with EPICS c# Library Version 1.2.0.0 Bertrand Alain Gregor
