Subject: RE: CSS with a dynamic IOC (=labview?)
To: Touchard Dominique <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 20 Jun 2012 13:55:02 -0400
Hi Dominique,
Yes, this is possible. You can add a EditPartListener to a widget, which will be notified when a widget deactivated (removed or closed). See: http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.gef.doc.isv/reference/api/org/eclipse/gef/EditPartListener.html
So attach following Jython script to a widget on the OPI will do what you want. For complete example, see attached OPI.
from org.csstudio.opibuilder.scriptUtil import PVUtil, ConsoleUtil
from org.eclipse.gef import EditPartListener
class OPICloseListener(EditPartListener):
    def partDeactivated(self, editpart):
	ConsoleUtil.writeInfo("OPI Closed"); //replace this with the command to close your IOC
widget.addEditPartListener(OPICloseListener())
This script should only be executed once on OPI startup, so use a constant PV, for example "1" as the trigger PV will do that.
It is not recommended to attach this script (in fact, any script) to the display, because that won't work when this OPI is embedded in a linking container. When a  display is embedded in a linking container, only its children are loaded in the container so the scripts on the display itself will not be executed.
Cheers,
Xihui
Sent: Wednesday, June 20, 2012 11:42 AM
To: [email protected]
Subject: CSS with a dynamic IOC (=labview?)
My goal is to start a linux IOC inside CSS boy as a labview IDE. (NI@) Here, no trouble at all. But…
Is there any OPI property that runs a dedicated command when the user click on the cross to close the OPI. The goal is to stop the Linux IOC embedded with the OPI.
Thanks for your help.
Dominique Touchard.
Attachment: NotifiedOnDisplayClose.opi
Description: NotifiedOnDisplayClose.opi
CSS with a dynamic IOC (=labview?) Touchard Dominique
Prev: Re: dbd expand errors for measurementComputing module Tim Mooney
Next: Re: caxy-1.0.0 released; CA tunneling with SSH Martin Konrad
Prev: CSS with a dynamic IOC (=labview?) Touchard Dominique
Next: caxy-1.0.0 released; CA tunneling with SSH Till Straumann
