Subject: Re: caxy-1.0.0 released; CA tunneling with SSH
To: [email protected]
Date: Wed, 20 Jun 2012 22:07:32 +0200
Hi Till,
> http://www.slac.stanford.edu/~strauman/epics/caxy/
I think there is another way how you can access your IOCs from the
outside that is no on your list: You can use a VPN tunnel.
If you use OpenVPN you need to make sure that you use the TAP interface
on server and client. On the server side (inside machine) you can simply
bridge the tapX interface together with your ethX interface (if you
configure OpenVPN correctly this should happen automatically).
+you should not need to patch your JCA/CAJ/CSS for this - everything
should be transparent
+OpenVPN is widely supported (even on smartphone)
-once you are connected you can access everything (not restricted to CA,
this might be a security issue)
Did you try this approach as well?
Best regards
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
Re: caxy-1.0.0 released; CA tunneling with SSH Till Straumann
Prev: RE: CSS with a dynamic IOC (=labview?) Chen, Xihui
Next: Re: caxy-1.0.0 released; CA tunneling with SSH Till Straumann
Prev: caxy-1.0.0 released; CA tunneling with SSH Till Straumann
