Subject: RE: How to profile an EPICS application on Linux
To: "'J. Lewis Muir'" <[email protected]>
Date: Mon, 10 Sep 2012 22:21:03 +0000
Here is the output of "time" when running it in a mode where "top" showed the application using about 95% of a single CPU (on a 16 core system).  This is with my calculations enabled.
23.547u 16.516s 0:52.39 76.4%   0+0k 0+24io 0pf+0w
This is the output of time when the calculations are disabled and top shows about 80% CPU in my application.
Disabling my calculations:
11.401u 8.008s 0:27.60 70.2%    0+0k 0+8io 0pf+0w
So it spends a substantial amount of CPU time in both User Mode and Kernel Mode.
-----Original Message-----
Sent: Monday, September 10, 2012 5:03 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: How to profile an EPICS application on Linux
On 9/10/12 4:58 PM, Mark Rivers wrote:
> Hi Lewis,
> Thanks for the reply.
> I don't think that could be it, because I can reduce the CPU time of my application from 20% to 14% by changing a PV to eliminate calculations that are definitely done in my code.  I collected the profile with those calculations enabled, so at least (20-14)/20 = 30% of the CPU time should be in my calculation function.  It's spending the rest of its time reading short TCP messages which are coming in at 6.5 kHz, and I think that will result in a non-trivial amount of time in drvAsynIPPort.  Some of it will be in the system Ethernet driver, network stack, etc.
Hi, Mark.
What does the "time" command show?
Lewis
Re: How to profile an EPICS application on Linux J. Lewis Muir
How to profile an EPICS application on Linux Mark Rivers
RE: How to profile an EPICS application on Linux Mark Rivers
Prev: Re: How to profile an EPICS application on Linux J. Lewis Muir
Next: Re: camonitor bug for string as array of chars Andrew Johnson
Next: Re: How to profile an EPICS application on Linux J. Lewis Muir
